Results 1 to 10 of 19
Thread: 6.0 build
    central TX
    6.0 build
    hey guys i just bought a 6.0 short block in good shape. what im looking at doing is getting it to the machine shop and getting it cleaned up with a new set of pistons and rods. I have a fogger system im going to put on it with a victor intake and a 850 carb. Im looking for around 11:1 compression if not more no worries ill run a mix of race gas. Im new to ls base engines and am up for any ideas. any ideas on a cam anyone has had good luck with the hose? whatcha think?
    93' chevy 1/2 ton,6/8 drop,L31 engine swap ,GM performance intake TBI to vortec,Jet regulator
    LT4 hot cam 218/228, Lift .525/.525, 112*
    roller rockers
    MSD 6AL, coil, 8.5 wires
    LT's
    shift kit/ billet servo
    6.0 nitrous build in process
    Quote Originally Posted by slammed 93 View Post
    keeping stock bore size? the vic jr on a NA motor will suffer in the lower rpm range, there more suited for a bigger bore motor. what heads you plan on running?
    Simple: 408 on steroids!
    single digits coming soon!
    central TX
    Quote Originally Posted by skeet View Post
    You think so? And on the heads, a friend of mine hooked me up on a set of ls1 heads and beehive springs for nothing. My plan was to get then worked on a bit. Sorta on a budget I'm trying to build the whole truck cage & 4 link.
    so youre keeping the stock bore size? just getting forged pistons and rods?
    if youre going that far into id get some stock flaptops and throw in there, hell stock lq9s if ya want, then some 243s or l92 heads, you wont need race gasket with 11:1 unless you wanna try and throw alot of timing at it
    nice healthy cam/ along with a nice size stall, then you'll be ready for a 4 link and and cage
    central TX
    you think that the pistons will hold a 150-250 shot? and yea i was wanting to throw some timing at it, my old man knows how to set a carb up with some hose so i can get the most out of it. yea i may try and see these ls1 heads i got they came off of a very low mile 2002 camero. on the cage my dad is a chassis man also so i got all the time and benders needed for the cage as well with the chrome moly tubing so im wanting to do my own set up as well with the 4 link. what the average price of a set of the 243's or l92's?
    roller rockers
    LT's
    stock lq9 pistons will hold up to a 150 shot, i was running numerous times 100 shot on a stock lq9 id say even a 200-250 maybe more pending on the tune it would have to be dead on . youll find 243s for around 250-350 l92s are about 100 to 150 more. nice to have a dad like that. i prefer t he l92s but the shit gets expensive hell i got 2500 just in head work and valves and springs lol!!
    sound like you want something serious but also wanna stay on a budget? is there a ET you gunning for?
    central TX
    Haha sweet man good to hear, I think with a wideband ill be able to tune it pretty well. hell yea right let her eat!
    AFR should be monitored on a wideband, but tuned via plugs. My truck has always liked things a little leaner (or maybe I do).
    central TX
    Right forsure, haha right squeezing all the power you can it sounds like.
    If you aren't living on the edge, you're taking up too much space.
