Results 1 to 10 of 29
Thread: 5.3 and 4L60E Swap
    Nov 2009
    Fort Smith, Arkansas
    I am in the planning stage of basically the same swap but a 2wd. The only part Im not sure on is the wiring.
    Dec 2009
    Alabama
    I have a link for someone if you need it. He has good feed back. But i am about to have he outfit a wiring harness for me. He can delete anything you are not going to run like rear 02, EGR etc.. and also have a link for someone that can reprogram the computer to run with out what you have deleted. just hit me up if you need the info. positive feed back on both people and prices are good.
    Nov 2009
    Quote Originally Posted by 87OldYeller View Post
    Please share what you know....
    If the guy's name is Oscar, save your time and money.
    ff_jeff Guest
    Quote Originally Posted by flattopwill View Post
    Nelson performance made my harness. GREAT quality. and they build to your specs. Nelson Performance - Performance without Sacrificing Drivability
    Nov 2009
    A Nelson harness is in the plans but man I'm so lost when it comes to wiring I won't know what to do with it when I get it. I don't know what stays and what gets ripped out nor do I know how to mesh it with what stays.
    ff_jeff Guest
    its easy. Only need to make like 5 connections. Battery, ignition, fuel pump, tach. and speedo. the rest is plug and play.
