Results 1 to 10 of 29
Thread: 5.3 and 4L60E Swap
    Dec 2009
    Easley, SC
    5.3 and 4L60E Swap
    So I am wanting to swap my 5.7 TBI & 700R4 with a 5.3 & 4L60E. I am going to be making the swap in a 1990 K1500 short bed regular cab pickup. I am looking for any advice from anyone that has done this swap or a similar one to help the process go as smooth as possible.
    Dec 2004
    San Antonio, TX Area
    I'm in the middle of almost the exact same swap, except it is a 1990 C-1500. Welcome to the site.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Dec 2009
    Easley, SC
    Cool
    Thanks...Yeah I think I have a lot of the issues worked out, but right now the biggest question I have is what to do about the A/C compressor, any ideas?
    Gramercy
    there is a way to keep your stock AC...it puts it on top of the motor without having to change the compressors
    2008 GMC CCSB 6.2/6L80e swap
    Nov 2009
    Fort Smith, Arkansas
    Basically you have a few options..
    http://www.ls1truck.com/forums/lsx-t...-solution.html
    or
    Whats up with the AC, hope you have the answers - LS1TECH
    or
    Kwik Performance, Inc. products - LS1 and big block Chevy
    or
    S&P's ~$700 kit
    or
    There is a guy on pt.net that makes a high mount kit and sells it for $315. IMO I think it is the best option because it bolts right on with no modifications, it looks real good, and you use your own compressor. I have a link to it that I will l post tonight when I get on my own computer. (I'm on my phone)
    Nov 2009
    ff_jeff Guest
    some advice. Get a complete pull out. all those little bolts and crap will break the bank.
    Nov 2009
    I am in the planning stage of basically the same swap but a 2wd. The only part Im not sure on is the wiring.
    I have a set of those AC brackets ordered right now.
    Dec 2009
    Alabama
    I have a link for someone if you need it. He has good feed back. But i am about to have he outfit a wiring harness for me. He can delete anything you are not going to run like rear 02, EGR etc.. and also have a link for someone that can reprogram the computer to run with out what you have deleted. just hit me up if you need the info. positive feed back on both people and prices are good.
