Results 1 to 3 of 3
Thread: 6 Speed
    Feb 2010
    Allen, Tx
    6 Speed
    So i am looking into converting my 2002 4.8 to a 6 speed T-56. What all will i need?
    2002 4.8, MSD Ignition, 2" Rear Lowering, dual magnaflows, custom cai.
    Waiting: Nelson Tune, Lt, 2/4 drop, high flow cats, TSP Custom Grind Cam
    Hope Mills, NC
    f body t56, heavy duty clutch (ls1, ls2,ls7) style dont go with a stock ls1 clutch. i dont even have a thousand miles on it yet and shes burned up already. f body thowout bearing, 02 fbody slave, your driveshaft will be the same. a sweet shifter extension will be needed. i cant remember if i am missing anything here. im sure someone else will chime in
    2005 GMC RST *sold
    2006 Silverado SS with nawz
    Feb 2008
    Quote Originally Posted by SNEEKY View Post
    alos 5 speed truck trans crossmember, clutch pedal assembly out of a manual truck, theres alot of write ups on performance trucks on renforcing the clutch pedal assembly so it can take hard shifts! gotta find that, think the 6 speed swap is the way to go these days...ive already started gathering parts for my swap as well!
    04 RCSB- 4.8- bolt-ons..nuff said
    carbs are for salads and lawnmowers,
