Originally Posted by
droopyzda1
I am in the process of that exact swap now. U have to tear out the V6 mounts. Use a cutting
wheel and air chisel to break the rivets holding the V6 mounts to the frame. Installing the V8 mounts are straight formats. I had my old man with an impact gun screwing in the bolts up top of the mounts as I was holding the bolts from the bottom in-between the frame. People have said that u have to remove the lower control arm, that's B.S. There is a gap between lower control arm and the frame. Get a long extension with swivel head and u are "f***king golden" !! I did it with some loc tite. Only had to use three bolts per mount to hold in place. I changed my fuel pump to a 1996 c1500 V8 model and it was easier when the bed is removed.
