Page 5 of 8 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 41 to 50 of 78
Thread: Engine and trans are in
  1. #41
    Laurel Bloomery TN
    I'm a lil late in the game here, but its a sharp ride and the install looks pretty clean!! Bet she'll haul once back out on the road!!!!!!
  2. #42
    Jun 2007
    maine
    Hey Red Any Imput!
    Quote Originally Posted by brian1987 View Post
    The four wires you have to connect on the harness from Nelson, I believe, are 12v constant, fuel pump, tach, and speedo .
    Maybe check with Red to be sure I haven't forgot anything as I am still learning as I go.
    hmm no kidding! that doesnt sound to bad...hopefully the speedo will calibrate correctly... HEY RED ANY IMPUT!
  3. #43
    It's been a while since I saw one of the Nelson harnesses. One day maybe I'll have him build me one to clean up my under hood area.
    12v positive
    12v switched
    tach
    ground
    fuel pump
    starter
    alternator
    Tach is optional so there has to be another wire
    Speedometer calibration is in the PCM/tune
  4. #44
    Wow that thing looks really good!! I'm late on this too so forgive me for asking since its probably oosted but, What are the specs on this thing? Tranny and such?
  5. #45
    Mar 2005
    Atlanta, GA
    engine is a 5.3l, trans is a 4l60e and the rear end is the stock 10 bolt.
    1991 c1500. 5.3l and 4l60e swap in progress, next paint and body.
  6. #46
    what are you doing for fuel lines ?
  7. #47
    Mar 2005
    Atlanta, GA
    Since I have a return style fuel rails, I am reusing the original line up to the old fuel fitting where I will clamp some High pressure hose and use the fuel line connectors red posted in his sticky.
  8. #48
    Looks real good man!! What are using for tuning?
  9. #49
    Mar 2005
    Atlanta, GA
    I am using a PCM programmed by Nelson performance (farmtruc)
  10. #50
    Yep yep, should be a nice running machine once hes doen tuning it. I had a Nelson tune for a loooong time
