Results 1 to 10 of 10
Thread: which aeromotive regulator for 98 LS1 w/ return
    North Georgia
    I have a 98 LS1 with a return setup. I have a Walbro from Allen. Which Aeromotive regulator do I need? I also plan on adding a Magnacharger if that matters. Can I mount the regulator between the pump and the motor on the pressure side? Thanks for any help. Ryan
    The Corvette inspired Silverado is now rolling strong!
    http://www.ls1truck.com/forums/lsx-t...silverado.html
    San Marcos Texas
    This is what I used. http://store.summitracing.com/partdetail.a...mp;autoview=sku It would work better to mount it in the return line from the fuel rail to the tank. You can use it in the feed line but you will end up plugging off the return line on the fuel rail. In the return line will be better for FI.
    North Georgia
    Arrow
    <div class='quotetop'>QUOTE(GMCwantsLS1 &#064; Jan 22 2007, 01&#58;35 PM) [snapback]80746[/snapback]</div>
    Allen said the same thing. I dont understand why the return is better. I am used to carb motors. It seems to me iit needs to be regulated before the motor ever sees it. How can the return regulate the pressure side? Please explain. Thanks, Ryan
    <div class='quotetop'>QUOTE(86 Silverado LS1 &#064; Jan 22 2007, 05&#58;13 PM) [snapback]80769[/snapback]</div>
    What is best about a return type system is that the fuel supply stays cooler. The fresh fuel runs all the way through the injector rails before deadheading at the regulator. When the fuel pressure builds up past the regulated amount it is returned to the fuel cell to join the rest of the cooler fuel.
    San Marcos Texas
    It will work either way. The regualtor after the injectors will like Red said keep the system cooler due to the flow through of fuel, and the last injector will more likely see the same fuel pressure as the ones closer to the feed in line. A tiny bit of difference in fuel delivery on a forced induction engine will kill a piston quick. Mine is a dead head system since it is a 2002 setup.
    Jeff, why not go ahead and do a return type system? You can buy the edelbrock fuel rails very reasonably, for under &#036;200 you could completely convert it over to a flow thru system.
    North Georgia
    IT LIVES&#33; I just fired it up. More to come. Ryan
    Oct 2005
    Baton Rouge, LA
    What?&#33;?&#33;?&#33; No video&#33;&#33;&#33;
    North Georgia
    <div class='quotetop'>QUOTE(1BADC10 &#064; Jan 22 2007, 10&#58;26 PM) [snapback]80825[/snapback]</div>
    It wasnt that pretty. Just ran for a few seconds before I shut her down. Im pretty sure there are some stuck injectors as long as it sat. Ill get back on that tonight. Im just happy to hear it run.
    San Marcos Texas
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jan 22 2007, 07&#58;17 PM) [snapback]80802[/snapback]</div>
    I was thinking about getting a set of fuel rails and doing that. I think I&#39;ll redo everything soon. It should look completely different.
