im puting a 4.8 and 4l60e in my 55 fairlane and i wanted to do a little to it nothin to extream an i was wondering about cam choices some thing mild
<div class='quotetop'>QUOTE(ls55 @ Jan 10 2007, 12:40 PM) [snapback]78962[/snapback]</div>Go with something with around 220ish duration with around 550 lift on 112 lsa. Dont forget ya gotta upgrade your springs and may as well get hardened pushrods.im puting a 4.8 and 4l60e in my 55 fairlane and i wanted to do a little to it nothin to extream an i was wondering about cam choices some thing mild
thanks who makes a came like this
<div class='quotetop'>QUOTE(ls55 @ Jan 10 2007, 01:47 PM) [snapback]78995[/snapback]</div>.If I were you and your gonna get nelson to rework your harness get him to recommend you a cam. He's a dealer for comp.Check the classifieds for a used cam,roller cams dont wear out like traditional cams, and people upgrade to larger cams all the time. You should be able to purchase a used one for 200 bones. You should also be looking for a stall convertor with maybe a 2000-2600 stall speed.A trailblazer convertor is a very good upgrade over the factory verter.I may get in trouble for this but also try ls1-tech look under conversions and hybrids tons of info there also. Look in there classifieds for a used cam.That is if you cant find one here.thanks who makes a came like this
