Results 1 to 8 of 8
Thread: Jammed auto trans dipstick
    Oct 2006
    Any one had a tranny dipstick feel stuck before? I unlock it and go to remove it, but it feels like it's stuck solid. I'm over due on checking it, and wondered if anyone had any tricks to try.
    San Marcos Texas
    Try twisting it back and forth. If you still can't get it unstuck you might unbolt the whole tube and pull it out of the tranny then you could push it up..
    Nov 2005
    ohio
    Yes, after having the trans built in my Z-71, it was "hard" to pull out, just be easy on it and pull it out firm, it will be ok!
    DBYRD Guest
    i got a lokar dipstick with teflon(very very flexible) dipstick material, and its smooth. looks great too!
    Apr 2006
    Once you get it out, wipe some white lithium or vaseoline around the rubber seal. You may be able to heat it a little with a heat gun to loosen it.
    Dave
    2003 Silverado SS here's where my money went...Radix @ 9psi, Vortec IC tank, Oversized Heat exchanger, ASM LT Headers, Suncoast Ram Air hood, Airaid intake, Trailblazer Torque converter, Full billet servos, Zippy kit, cat-free, Flowmaster muffler, Gaylord Speedstur tonneau, 3/4 drop with Belltech spindles and leafs, Sirius conversion & MTX thunderform sub box. 05 e-fans coming soon!
    When you release the lever, you have to shove it downwards to release the dipstick, then pull it out. It's part of the locking mechanism.
    Oct 2006
    Right on guys, finally came out no sweat. I hadn't popped one of those in a while and probably would have ripped something apart if I didn't check here first. Fluid is burnt as hell and needs to be changed immiediately.
    Sep 2004
    Breaux Bridge, LA
    <div class='quotetop'>QUOTE(Tim Z &#064; Oct 30 2006, 08&#58;02 PM) [snapback]71689[/snapback]</div>
    Yes, after having the trans built in my Z-71, it was "hard" to pull out, just be easy on it and pull it out firm, it will be ok&#33;
    mine does the same
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
