Results 1 to 10 of 23
Thread: HELP
    May 2006
    Waco TX
    OK this is the deal. The 6.0L is all hooked up mounted and everything. You turn the key on and it does everything right, just wont start. wont even turn over. I was reading forums before and ive heard the the fuse/box/PCM is dif on a 4.3L and a 6.0L. Where can I get a wiring diagram so I can go in there manualy and put everything in the right Pin #. Ive seached the internet and nothing. It is a 99 4.3L V6. and the new motor is out of a 2001 2500 HD 6.0L LQ4. Im needing yall bed guys. Please HELP!!
    Daniel
    May 2004
    What PCM are you using? Have you disabled the VAT's?
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    May 2006
    Waco TX
    <div class='quotetop'>QUOTE(NITROUS &#064; Aug 25 2006, 02&#58;07 PM) [snapback]62383[/snapback]</div>
    What PCM are you using? Have you disabled the VAT&#39;s?
    Using the PCM from the 6.0L
    <div class='quotetop'>QUOTE(SCIV &#064; Aug 25 2006, 02&#58;12 PM) [snapback]62386[/snapback]</div>
    a little off topic, but how many times a week do you change your sig??
    Oh, I&#39;m not complaining on the new one&#33;&#33;
    Haha. I was just playing around with some stuff. This new one is here to stay. I like it too much.
    <div class='quotetop'>QUOTE(kwkenuf &#064; Aug 25 2006, 03&#58;42 PM) [snapback]62391[/snapback]</div>
    I&#39;ve probably got the diagrams you need at home in electronic format if my CD goes back that far. I&#39;ll check for starting diagrams for both models after I get off work. I believe this topic has been addresded before on this forum however. A search might yield the info you need. Another way to get the info would be to subscribe to Alldata on the web. Or perhaps hummertech will see this, he has been very helpful to others on wiring diagrams.
    Oh, and if it is not even turning over, disabling VATS in your PCM is not the issue. But you must address the VATS issue to get it to run longer than a couple of seconds.
    Ive seached and found some LS1 diagrams, but that doesnt help any. I looked into Alldata, but I was going to see if anyone on here knew or had the diagrams before i though about the subscription. Its not even turning over, so VATS isnt an issue right now. If you can please help me with these 2 diagrams so we can get the Pins changed to the right ones&#33;&#33;&#33; Were almost complete&#33; Thanks man
    Apr 2005
    Gone, but not forgotten!
    DBYRD Guest
    haha hey u can thank me for his sigs haha i did one and he liked it but hes done the last two, and they look pretty sweet. look for QUICKSILVER TRUCK CLUB to be a new member soon got something for ya&#39;ll&#33;
    Jan 2006
    Las Vegas, Nevada
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
    May 2004
    Sorry about that, I read a little fast and didn&#39;t see it wouldn&#39;t start period. Let me see if I have a diagram.
    97 GMC, 2002 LS6.
    Oct 2005
    Baton Rouge, LA
    When I had that problem, I found that the big purple wire wasn&#39;t getting power. bypassed the fuse block&#39;s relay, and "BAM&#33;" The starter lead from your old setup is usually a thick-gauged wire (red or purple) that comes from your old fuse block. You CAN probe with a multimeter to check you voltages to confirm you&#39;re getting power to the necessary points you need power to.
    Apr 2005
    belton, tx
    The multimeter is your friend. Check to see if 12v is making it from the ignition to the starter. Isolate the blockage.
    2013 2wd Z71 6.2 crew cab
    Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
    best time 12.93 1/4 mi @ 103 in the turbo truck.
    1968 Camaro Convertible, super sweet!
    May 2006
    Waco TX
    <div class='quotetop'>QUOTE(stssilverado &#064; Aug 26 2006, 10&#58;32 AM) [snapback]62473[/snapback]</div>
    Remember Brandon. Its your mechanic doing all the work...... maybe you could help a little if ya run down there.
