Results 1 to 10 of 12
Thread: Just some random questions....
    Jun 2006
    The Socialist Union of Canada
    I've pretty much decided on the motor I want for my truck (5.3). But I'm wondering what tranny to use. I plan on going turbo, maybe an STS kit (If it's possible on an OBS truck). I'm leaning towards either a built 4l60e or a mild 4l80e.
    a stage 4 or 5 4L65E will do the job. Don't go cheap or you'll be doing it twice and paying way more than getting a good one the first time.
    Jun 2006
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Aug 21 2006, 08&#58;59 PM) [snapback]61932[/snapback]</div>
    a stage 4 or 5 4L65E will do the job. Don&#39;t go cheap or you&#39;ll be doing it twice and paying way more than getting a good one the first time.
    Thanks, that&#39;s why I&#39;m asking. I don&#39;t want to be pushing any sort of horsepower through a transmission that won&#39;t take the abuse. I&#39;m also thinking of getting a Gear Vendors unit, if that matters.
    Do you really need a double overdrive? The 4L65E will give you a good overdrive ratio. The only reason for a double overdrive would be if you were running 4.88 or greater gears.
    Jun 2006
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Aug 21 2006, 09&#58;07 PM) [snapback]61934[/snapback]</div>
    I&#39;m not sure of the gear ratios for the 4l65e, but the 4l60e has a very steep first gear (3.06) and a huge drop off into second (1.63).
    DBYRD Guest
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Aug 21 2006, 09&#58;59 PM) [snapback]61932[/snapback]</div>
    outta curiosity how much do those run?
    May 2006
    Waco TX
    Im not sure that the housing of a 4L80E tranny will match exaclty up to a 5.3. Itll work but the may be gaps. Then again im not sure
    DBYRD Guest
    <div class='quotetop'>QUOTE(Red03SilSS &#064; Aug 22 2006, 03&#58;06 PM) [snapback]61981[/snapback]</div>
    yeah it should since its a v8 tranny. the only reason mine doesnt match up perfectly is cuz it came out of a v6. v8 bellhousings r probably all the same
    Aug 2005
    St. Anthony, Indiana
    Nov 2005
    Turbo would be badass. Frount mount or rear etherway BADASS&#33;&#33;
    I can have your 4l60e built for about &#036;1100. I have not had one of these built trannys brake yet&#33;&#33; We have been putting them behind some pretty badass turbo LS1&#39;s and 6.0L 408&#39;s&#33;
    Just give me or Billy a call.
    817-703-3750
    SOON TO COME!!!!
