<div class='quotetop'>QUOTE(RedHeartbeat @ Jul 7 2006, 02:19 PM) [snapback]57363[/snapback]</div>
Gotta pull the pan off the rear end. Clean it up real good when you're done so it won't leak. GM uses silicone now to seal the rear cover. I still use a paper gasket and never get leaks. The best way to change the fluid is to park it pointed uphill so the fluid drains out of the pumpkin. I usually get a spray can of brake cleaner and wash down the insides of the casting to get as much old oil and trash out as possible. $149 to change rear end lube? Damn, I'm in the wrong business. Replace with Royal Purple since it already has all the additive in it for limited slip diffs.
Subject: Info - Rear Axle Lubricant Compatibility and Usage #99-04-20-001 - (06/18/1999)
This bulletin is being issued to inform dealers about the compatibility and usage of the new Fuel Efficient SAE 75W-90 Synthetic Axle Lubricant, GM P/N 12378261 (In Canada use P/N 10953455), with current axles, and with the non-synthetic axle lubricant, GM P/N 1052271 (In Canada use P/N 10950849), for the rear axles on the above light-duty trucks.
just some info, but i dont know about non gm synethic axle lube, i have seen racing 90w synethic not atack rtv. the gm axle fluid is not uasable on a silicone axle, unless you want a leak.
gm synethic axle fluid is $25.00 a quart.
8.5/8.625=2qts
9.5/9.5ld=3qts
10.5=3.5qts
11.5=4qts
38" swampers, 350 tbi, 14 bolt rear, 10 bolt front
