Results 1 to 10 of 20
Thread: lowering heigth
    Nov 2005
    i have lowered my truck using spindles in the front, and for the rear i used 2inch drop shackles and 2 inch drop hangers, then removed my load leafspring. My question is, if i put 2 inch drop coils up front, would that be to much rake, or should i just get 1inch drop springs? thanks for any suggestions. here is a picture of my truck on level ground:
    Project: 91' short wide:
    GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's
    5/7 drop, almost totally shaved and 93 Deville tails
    Future Plans: 2001 LQ4 6.0L & a T-56
    DD: 98' 5 speed GT : Dumped Exhaust, CAI
    Jan 2006
    I guess it depends on what you want. I personally don't like alot of rake. So with that being said if you want to have some rake my opinion is 1" lower springs up front and 3" shackles and put an air dam back on the front bumper.
    Putting an air dam back on it will make it look lower in the front.
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
    Nov 2005
    <div class='quotetop'>QUOTE(motoxlifer &#064; Jun 10 2006, 10&#58;29 PM) [snapback]55173[/snapback]</div>
    I guess it depends on what you want. I personally don&#39;t like alot of rake. So with that being said if you want to have some rake my opinion is 1" lower springs up front and 3" shackles and put an air dam back on the front bumper.
    so are you meaning to go back and put everything back on and just make it 3 inches? and i just bought the airdam with the foglight cutouts, i just cant afford the foglights haha
    Aug 2005
    Houston,Texas
    go with the 2" springs, I think it will look sharp. That wont be too much rake
    99 ECSB 5.3 LS6 CAM AND SOME BOLT-ONS BEST TIME 13.6@97MPH
    http://i104.photobucket.com/albums/m...wTRUCKS008.jpg
    If you saved the stock hangers for the springs, I&#39;d put them back in and do a 6" flip in the rear with the 2" spring up front. It&#39;ll be low but it will be level. 2" springs up front is going to give you the factory rake, again.
    Jan 2006
    <div class='quotetop'>QUOTE(c1500 &#064; Jun 10 2006, 11&#58;33 PM) [snapback]55179[/snapback]</div>
    Well I thought you could get 3" drop shackles but maybe not. If not then I would just leave it alone and put your airdam on or go with Red&#39;s idea if you feel like spending the money and doing the extra work. I think if you go 1 or 2 more inches lower in the front and don&#39;t lower the rear with it, the rake would be too much imo.
    Nov 2005
    <div class='quotetop'>QUOTE(motoxlifer &#064; Jun 11 2006, 01&#58;06 PM) [snapback]55196[/snapback]</div>
    yeah so i think ill just put the airdam back on when i get my fog lights, i dont think have the stock hangers(the ones nthat are up front?) any more, and it was already lowered with the other peice( the shackles..the ones in the rear)... i really wish i would have bought a 4/6 kit, but if i can find the stock peices again, i might go back and lower it 6in the rear with a flip kit..thanks for the input guys
    Jan 2005
    Humble/Houston TX
    i already think it has too much rake...but if you like the rake go for it
    old mod list: H/C/I/N/E/G 408
    You could buy a 2" drop rear spring and c-notch the rear to get it down without a flip kit since you already have 4" of drop. I&#39;m not sure if removing the heavy overload spring actually drops the rear any more than the thickness of the spring.
    Nov 2005
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jun 11 2006, 05&#58;35 PM) [snapback]55208[/snapback]</div>
    Would i be able to just C-notch the frame and put the rear end on top of the leafs, or will that just make it way to low with what i already have on it? could i re-install the original shackels and not the hangers (the ones that are at the way rear of the truck) and then flip the rear axle? I have looked for 2" drop leafs and could only find 3 inch lowering leafs. .....when i removed the heavy load spring, im guessing its about 3/4 of an inch or less...but i dont really think it was worth the effort removing..thanks
