Results 1 to 3 of 3
Thread: Plumbing questions
    Feb 2004
    As my project progresses I'm about to finish the chassis.
    Before I go and buy new prebent hardlines for the fuel and trans, I want to know if they will work w/ the LS1 setup, and if any mods need to be done to them to make them work?
    '91 chev. Reg. Cab SB. Frame off, escalade clip, ART F&R susp., SSBC rear disks, SSBC Force 10 front kit, Auburn LSD, '00 LS1 and 4l60e. Almost all done!
    http://s57.photobucket.com/albums/g220/98hd/Chev/
    Jan 2006
    Las Vegas, Nevada
    <div class='quotetop'>QUOTE(98hd &#064; May 25 2006, 11&#58;17 AM) [snapback]54013[/snapback]</div>
    As my project progresses I&#39;m about to finish the chassis.
    Before I go and buy new prebent hardlines for the fuel and trans, I want to know if they will work w/ the LS1 setup, and if any mods need to be done to them to make them work? [/b]
    Depends.... what prebent lines are you buying? From what application?
    On mine I used 90% of the tranny hard lines from a 2002 Tahoe but had to cut off the ends (where they connect to the radiator) and use rubber hose to connect since I didn&#39;t have a stock radiator.
    My fuel lines are about 50% stock 2002 Tahoe, 45% AutoZone hardline, and 5% hi-pressure rubber hose. My fuel tank and pump are not stock and do not reside in the "stock" location so custom lines were needed. Both pressure and return are stock parts from the fuel rail back to the fuel filter mounted on the left frame rail, located roughly about mid-cab. From there I used double flared hardline back to the tank with the last foot or so the rubber line.
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
    Feb 2004
    Thought I had a sig line w/ the info, I guess not.
    It&#39;s a &#39;91 and I want to get the lines for the &#39;92 truck. Engine and trans are &#39;00 camaro.
    I would think the trans lines are the same, as they are different versions of the same model. Mostly I&#39;m unsure about the fuel lines from where the hardlines stop.
    &#39;91 chev. Reg. Cab SB. Frame off, escalade clip, ART F&R susp., SSBC rear disks, SSBC Force 10 front kit, Auburn LSD, &#39;00 LS1 and 4l60e. Almost all done&#33;
