hey i was just wondering if anyone out there has done the 4.3 to the ls1 swap?
yessir
[1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
Did a 92 4.3L to LT1 and then LS1 swap.
what kind of problems did you run into?
<div class='quotetop'>QUOTE(josh @ May 24 2006, 09:13 AM) [snapback]53932[/snapback]</div>what kind of problems did you run into?
You'll most likely run into different items than me since you have a 2002 truck. Your best bet would probably be to find a 5.3 or 6.0 so that you can get all the stuff that is normally in trucks like yours. You can do the other conversion without many issues but it would look pure stock-like with a truck engine instead of an fbody engine in there.
