I remember Greg saying that LS1's are pretty noisy. I can hear the valve train clicking which would seem pretty normal too me but I have a resonance tapping noise through the exhaust pipes which I can't track down. I have an SKF microlog at work that I can bring home to measure g's with an accelerometer but before I did that I wanted to know if anyone with a high lift cam has heard this same type noise. I tried putting pressure on the exhaust system with no luck of stoppng it and thought I'd ask you guys about it. When I rev the engine up either it disappears or the exhaust noise over rides it. I know if it was a bearing or something of that nature (mechanical), it would not go away, it would probably get worse. The S&P headers seem a little thin to me, does anyone with them get this noise? Thanks
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
- You may not post replies
- You may not edit your posts
