Results 1 to 10 of 25
Thread: Long tube Swap headers for 88-98 trucks
    Who here would buy a set of 1.75" diameter Hooker Competition long tube headers for their LS1/Gen3 truck if they were available? I have been in contact with Hooker to build us headers and they don't think there is enough demand for them. Nobody makes a set of long tubes for our trucks at this time and I know there are a lot of us out there with the Gen3/Gen4 engines. Post up if you would buy them if they were available and maybe we can get the word out. I am sure that the main issue will be engine placement. Hooker already sells an engine swap mount kit for our trucks and I am sure the headers would be designed with their mount controlling the engine placement front to rear.
    Also, go to their tech support area at www.holley.com and send a direct request for a set if you'd like to speed them up in development.
    Yes/No. 2wd/4wd Auto/Manual transmission
    This is also posted over on pt.net
    Jan 2006
    Yes\2wd\auto
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
    Nov 2005
    yes\2wd\manual
    Project: 91' short wide:
    GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's
    5/7 drop, almost totally shaved and 93 Deville tails
    Future Plans: 2001 LQ4 6.0L & a T-56
    DD: 98' 5 speed GT : Dumped Exhaust, CAI
    Oct 2005
    Yes/2wd/manual
    '92 Fullsize, swb rc
    5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
    Apr 2005
    Heck YEAH!!!!!!!!!& #33; 2wd/Auto
    93 Ext Cab w/ 99' LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
    Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
    Apr 2005
    I'm hearing you - and heeding the call:
    "Thank you. Your Request is #32871
    Technical Service Requests are answered in the order in which they were received. Please allow up to 48 hours for a response, though usually they are answered much more quickly." -
    "Why won't any header manufacturers make LS1 longtube headers for Chevy P/U where we've converted these trucks into well-tuned street performance trucks."
    Oct 2004
    Depends on price, but Yes/2WD/Manual
    Had a 91 SB, Open diff, 3.08 gears, stock LS1/T56. 14.8@95.9...sold.
    Now, 90 C1500 350tbi/NV3500....just bought a 5.3...need T56, Swap parts.....
    May 2003
    Definately
    4wd/auto
    Old: 1998 K1500 White ext cab stepside, vortec 350. Stock besides Volant intake.
    New: 1998 K1500 with stock LS2 besides LQ9 truck intake and 8.1L Marine injectors. Dynotuned, 350rwhp, custom 3.5" exhaust, '02 F-Body Racetronix fuel pump setup. All wiring, exhaust, motor brackets done in shop.
    Aug 2003
    Yes/4wd/auto
    1993 GMC Yukon 2dr 4x4, 6.0L/4L80E swap, Wheatley Tune, 3 inch Magnaflow true duals, 6.5 inch Dick Cepek stage 1 lift, 35's, 4.56 gears, front Posi-Lok.
    Maybe a better question is what headers have people tried that DON'T fit? I was thinking of trying Pacesetter LS1 F-body headers. On my end, if they don't fit my truck, they will fit my LS1-Impala project.
    Can we do a poll? If desired, I can start another thread so I don't wal all over this one....
    Mike
    http://kds-performance.com
    94 Silverado Z71 SCLB 4.8L LR4 Daily Driver
    93 GMC Sierra 2WD LS V8 Swap dun, run, rusted, stripped & junked
    1979 Caprice Coupe - LS Swapped - 11.76@115.8
