I need to know by wednesday if an 2004 8.1L 496 big block will bolt up to a T56 tranny? Someone has to know!?!?
Thanks,
Mike
Thanks,
Mike
Since the 80E and the 60E interchange, the T56 should also interchange. The true issue would be the flywheel and input shaft. Surely a flywheel from a 97 camaro would work if the 98 and newer camaro doesn't work. Have you posted this question in the transmission section on LS1Tech.com?
I see. Yes I did at the same time I posted it here. No bites yet. What do I do about the input shaft?
Does the 8.1 engine already have a flywheel or just a flex plate for an automatic transmission?
<div class='quotetop'>QUOTE(RedHeartbeat @ Apr 10 2006, 07:19 AM) [snapback]49766[/snapback]</div>Does the 8.1 engine already have a flywheel or just a flex plate for an automatic transmission?
I have no idea?
TTT
99 C5 cam/boltons 400rwhp
10 Sierra CC 6.2
03 Suburban 5.3
