Results 1 to 10 of 25
Thread: LS2 Swap Success and Dyno tuned
    May 2003
    I've had the truck up and running for awhile, but have been having problems getting the tune nailed down in HP Tuners. Finally decided to take the truck in and have a local company that has done a lot of work with the LS2 tune it. Ended up putting down 330rwhp on a Mustang dyno. There is an 8 to 12% correction factor between Mustang dyno to Dynojet. Being on the conservative side with 8% would be about 350rwhp on a dynojet. The truck is very fast for being a completely stock LS2 and running the older 6.0L truck intake and throttle body. I do have a trailblazer torque converter installed with a stall of 2600rpm. We took out most of the torque management and raised the shift point to 6180rpm. Everything works on the truck besides the fuel level gauge. Only custom part that was made for the entire swap were the engine mount adaptors. Everything else was off the shelf parts from either a NBS or OBS truck. ABS, Speedo, Cruise control etc all work. No need for a converter for the tach, I was able to adjust the tach resolution in HP tuners and got it reading within 50rpm. Truck has ZERO SES codes. Just had to disable VATs on the PCM.
    I'm running an '05 LS2, '05 4l65e out of an escalade, and a t-case out of a '04 NBS truck. Once I measured up the engine mount adaptors, we were able to use the stock rear driveshaft, and the front driveshaft from a NBS truck. Also used stock tranny lines, 6.0L exhaust manifolds, 6.0L cat pipes to a Flowmaster Y with 3.5" mandrel bent exhaust out from that.
    We used a 5.3L engine harness and PCM from a NBS truck and mated it to the OBS fuse panel and connectors coming out of the firewall. Wiring was by far the most tedious part of the project, but really wasnt all that bad.
    For the fuel pump, I bought a Racetronix kit for a '99+ F-Body and the pump dropped right in. I had to buy some intank fuel hose to connect the pump to the plastic fuel bucket fitting, but other than that, the Racetronix kit had everything needed for the install. Fuel system should easily support 600rwhp, closer to 700rwhp if we use a voltage booster. It also retains the stock Venturi feed system so no worries about running the pump dry when launching hard. I'm running the corvette fuel filter/regulator in place of the stock filter.
    We ran several 1/4 Mile simulators on the dyno, and the truck is running 14.2 @ 99mph. We had problems spinning the tires on the dyno also, so that wasn't helping the 1/4 mile times. Once the track opens up, I plan on seeing how accurate that is. From a standing start while brake torqueing, the truck will spin all 4 wheels for a couple of feet. I plan to eventually get some sort of headers for the truck, possibly a cam, a better intake, and will more than likely spray it at some point also. I also have e-fans and an a/c compressor to install yet. Should get those on in the next week or so hopefully.
    I'll try and get some pics up in the next day or two.
    Old: 1998 K1500 White ext cab stepside, vortec 350. Stock besides Volant intake.
    New: 1998 K1500 with stock LS2 besides LQ9 truck intake and 8.1L Marine injectors. Dynotuned, 350rwhp, custom 3.5" exhaust, '02 F-Body Racetronix fuel pump setup. All wiring, exhaust, motor brackets done in shop.
    May 2004
    Sounds like you did a great job! How about some pics? What year model is the truck?
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    May 2003
    <div class='quotetop'>QUOTE(NITROUS &#064; Apr 6 2006, 04&#58;41 AM) [snapback]49451[/snapback]</div>
    Sounds like you did a great job&#33; How about some pics? What year model is the truck?
    I&#39;ll try and get some pics up later today.
    It&#39;s a white &#39;98 Extended cab step side.
    New: 1998 K1500 with stock LS2 besides LQ9 truck intake and 8.1L Marine injectors. Dynotuned, 350rwhp, custom 3.5" exhaust, &#39;02 F-Body Racetronix fuel pump setup. All wiring, exhaust, motor brackets done in shop.
    Sounds awesome. I&#39;d try the Hooker NBS headers and see if they&#39;ll fit in there. The way they run their pipes grouped together just might work in the OBS truck. If they don&#39;t, you have a set of LTs for your NBS truck.
    Jan 2006
    That&#39;s sounds awesome man. Where were you when I was trying to hook up my factory guages? Oh well it worked out pretty good the way I did it, just cost me an additional 500 bones. Yeah I want to see some pics too.
    Sep 2004
    Breaux Bridge, LA
    sounds like a good combo you got there.
    y not run the ls2 or ls6 intake?
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
    May 2003
    <div class='quotetop'>QUOTE(bluecajun5.3 &#064; Apr 6 2006, 03&#58;14 PM) [snapback]49486[/snapback]</div>
    I had the old 6.0L intake in my garage so I just used it. When I upgrade my Camaro to a FAST intake, I&#39;ll probably put that LS2 intake on the truck.
    Finally got a few pics of the swap: www.eadperformance.com/ls2truck/
    We just got a ton of rain today, and I live on a dirt road so the rest of the truck is very dirty. I&#39;ll try and get some more pics once everything gets washed.
    Oct 2005
    Baton Rouge, LA
    Ha Ha... wasn&#39;t gonna say anything about dirt, but nice swap.
    San Marcos Texas
    Nice job&#33; I like the green wire wraped around the coolant overflow tank hose&#33; J/K I bet it hauls&#33;
    Looks good plus you got me beat by 100 HP. What are you going to do for A/C? 2-80? 2 windows down and 80 mph?
