Results 1 to 4 of 4
Thread: removing EGR valve
    Feb 2006
    When removing the egr valve is there a plate you can get to install in its place? I seen in the part numbers list a number for a plate. Is that for the exhaust manifold or the intake. I'm using a exhaust manifold without a egr hookup,need to know what to do with the other end.
    There is a GM part number for a block off for an LS1 intake. I don't know if it's the same one or size for a truck intake. Some have used a rubber engine block freeze plug in the LS1 intake.
    Jan 2005
    Conway, AR
    yes they are the same, i got mine from ls1speed.com for like $8.
    Chris
    Feb 2006
    Thanks guys didn't know how to do it.
