[attachmentid=510]New, never installed, in box tachometer...First $200 + shipping gets it
The following is from summitracing.com:
ATM-6856 $269.88
Estimated Ship Date: Today
Application Suggested Parts Show All
Brand: Auto Meter
Product Line: Auto Meter Ultra-Lite Pro-Comp II Tachometers
Tachometer Usage: Standard
Gauge Series: Analog
Gauge Range: 0-9,000 rpm
Diameter (in)VL: 5.000 in.
Diameter (mm)VL: 127.00mm
Sweep: Full sweep
Shift Light: External
Tachometer Installation: Universal
Gauge Face Color: Silver
Gauge Number Color: Black
Pointer Color: Red
Bezel Color: Silver
Shift Light Color: Amber
Shift Light Diameter (in)VL: 0.625 in.
Rev Limiter: No
Memory Recall: Yes
Playback: No
OEM Replacement: No
Sending Unit: Electrical
Quantity: Sold individually.
Footnotes: 1 - Operates on 4, 6, or 8-cylinder engines with points, electronic, and most 12 V high-performance racing ignitions.
3 - Two-stage Shift-Lite.
Gauge Type: Tachometer
Tachometer, Ultra Lite Pro Comp II, 0-9,000 rpm, 5 in., Analog, Electrical, with Shift Light/Memory, Each
Check to make sure this part fits your application
Performance parts from a name you can trust.
Auto Meter's Ultra-Lite Pro-Comp II silver tachometers include a two-stage shift light. This feature gives the driver two shift settings. The first setting can be set lower to allow for reaction time with a fast-revving first gear. The second setting can be set at a normal shift point. The bright amber Quick Lite and Dial-In-Exactness features give instant notice of shift points, providing faster response times during shifts. These tachs feature a dial face that dramatically expands the most critical racing rpm range.
2000 ProCharged Silverado
11.94 @ 111.62
![](image.php?s=dcb5e67760142a1d78c290e410d36d73&u=1932&type=sigpic&dateline=1473714981)
"I never met a pound of boost I didn't like."
~ Jeff Harris / Mo's Speed Shop - Dallas, GA
current bid is $180.00 on ebay for this if you guys or someone you know may want to get in the running...
ends Friday afternoon
11.94 @ 111.62
SOLD on ebay $217.50+ shipping
Thanks guys
11.94 @ 111.62
- You may not post replies
- You may not edit your posts
