Results 1 to 10 of 11
Thread: check out these $30 top covers
    Top covers
    Ive never seen this before. Pretty cool. How do you cut and bend the acrylic?
    Building a 86 Silverado 2wd sbrc, LS1 and 4L60E. Magnacharger soon to follow
    HIS: 01 GMC Sierra 1500 H.D. 4X4 crew cab, loaded, 6" RCD, 3" body, 14X36" TSL Swampers, 16.5X12 MT classic 2`s, cowl hood, hypertech
    HERS: 01 GMC Yukon, loaded, Denali front clip, 22" Giovannas, 2/4 drop, cowl hood, 2 baby seats
    Jan 2006
    San Antonio
    Interesting setup.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    Anybody know how to make these? Will factory covers work with a magnacharger?
    Hello? .... Anyone ever worked with this stuff before. We need to figure these out. Much cheaper than the factory ones and we can add our personal touck with paint, vinyl or both. Ive got a plotter we use for tint graphics so if I can make the clear covers I can add just about anything to them. LS1 emblems, Corvette crossflags, Nelson Performance, LS1truck.com...Anything. The vinyl/paint would be on the bottom side so it would look cool and last. I just need to figure out how to make the clear covers. Thanks, Ryan
    I believe you can bend acrylic with a heat gun. Go to home depot and buy a test piece and give it a try.
    Jul 2005
    Galesburg Il
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Mar 23 2006, 08&#58;37 PM) [snapback]47995[/snapback]</div>
    I don&#39;t think his were bent. Will exhaust heat melt the acrylic?
    2002 white Silverado ext cab. Taillights filled, roll pan w/93 Cad lights horizontally placed, tailgate handle inside, Gaylord tonneau, bed slide & bed rug, all trim removed, Escalade door handles, 18" Enkei & Falcons, Speed grill. Grill shell, bumper pad, & valance painted white. Mirrors painted white. Many interior pcs painted black (over beige), black leather seat inserts and sun visors. 2" dropped DJM lower control arm, shackles/hangers for 4" rear drop. Engine: 5.3 , Radix w 2.8" pulley, 90 mm throttle body, Dart 225 heads, Comp Cam 581-588 224-230 on 114. ARP head bolts. KTech rod bolts. Alky Control methanol injection, Pacesetter lt&#39;s into elec cutouts then 4" polished Magnaflow SS mufflers then 4" ovalized SS pipes exiting in front of rear wheels both sides, gas tank removed and 24 gal. fuel cell where spare tire was w/Aeromotive pump, pre and post filters and pump controller & -10 SS fuel line. 160 thermostat MSD wires & Perma Cool fan, 34" radiator, Meziere elec water pump. Valve covers, alternator & brackets powdercoated white. Built 4l60e, 4.56 with Detroit Locker Trutrack. 2 Interceptor logging guages, FAST dual 02 sensor wb gauge, Cyberdyne vac/boost gauge. Truck is actually the property of a little Benji type dog. Pics of him and the truck too www.swardphotos.shutterfly.com
    Jan 2006
    I think you would need more than just a heat gun. I think you would need some sort of template to form them to, like a factory set of covers. I got mine from ebay for &#036;50. That&#39;s not a lot of money when you think about how much &#036;&#036;&#036; you could make selling these covers.
    You&#39;re going to need something more than a blow drier.
    They vacuum form acrylic sheets to make all kinds of items. I&#39;m just not sure what they use to heat the sheet so that it doesn&#39;t shatter.
    Dec 2005
    Dallas, TX
    Damn those covers add that much power. Im getting some&#33;&#33;&#33;&#33;&#33;&#33;&#33; LOL
    2001 GMC Sierra C3 with the 6.0&#33; Vararam King Cobra, TB bypass, No cats with two 3 inch cut outs and thats it for the motor. FOR NOW ATLEAST&#33;&#33;
    9.5 in the 8 mile
    6000K xrtalight h.i.d kit
    North Georgia
    <div class='quotetop'>QUOTE(stec3ve &#064; Mar 24 2006, 11&#58;49 PM) [snapback]48184[/snapback]</div>
    At 9.5 in the 8 you might want to give them a try&#33; Gotta love those extremely helpful post.
    The Corvette inspired Silverado is now rolling strong!
    http://www.ls1truck.com/forums/lsx-t...silverado.html
