Results 1 to 10 of 11
Thread: Ain't that a B!&*$
    Apr 2005
    belton, tx
    Motor is in, running, sounds awesome. Installed intercooler. T74 turbo is in. Motor revs like a freakin' race car. Went to put in gear and all hell broke loose. Apparently the torque converter (TCI), wheather by installation error or mechanical damage, welded it's self to the output shaft on the tranny. If no damage to the tranny, will just replace the TC.
    Silver lining=the installer said he'd "give" me a Yank 3200 to replace it.
    I have faith in his work so far.
    Check out sig for new motor specs!!!
    2013 2wd Z71 6.2 crew cab
    Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
    best time 12.93 1/4 mi @ 103 in the turbo truck.
    1968 Camaro Convertible, super sweet!
    Nov 2005
    ohio
    wow that sux! but at least your motor sounds good, youll be driving it in no time. remember., it's all your nephews fault! do you still have your old turbo or does sts have some sort of turbo upgrade prgram?
    Sorry to hear about the crap convertor. You'll be happy with the Yank. Can't wait to see the numbers or to see it run.
    Apr 2005
    belton, tx
    Still have the T-60. Looks like a piece of metal (piston) bent up the exhaust side. A local turbo shop says they can upgrade it to t67 for a couple hundred bucks.
    Nov 2005
    ohio
    so is the new turbo designed for rear mount use? i just wandered for "maybe" a down the road upgrade.
    Feb 2006
    <div class='quotetop'>QUOTE(Tim Z &#064; Feb 14 2006, 09&#58;52 PM) [snapback]44461[/snapback]</div>
    STS can usually resale Gt67s pretty easily with a GT76 swap. The 60s aren&#39;t too valuable to STS but you could always sell it on ebay.
    02 SS Camaro with STS kit running 5/8 PSI for 416/502 RWHP, 445/535 rwtrq-running methanol injection at 8 PSI
    &#39;97 Burb with 139K miles LS1 or STS kit or Gen IV 6.2L, etc...?
    Dec 2003
    Newark, Tx.
    Brandon, you will love the Yank. It should be looser and stall better and easier. Still sucks though. I am ready to see some results.
    Apr 2005
    belton, tx
    You and me both&#33;
    Jun 2004
    george west texas
    wow...good luck with it....shouldnt be a problem if your builders gonna fix it...
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Oct 2005
    Houston, Tx
    man ..whats next?&#33; at least the hard part is done though. tranny stuff is easy as long as its not internal. GET ER DONE MAN&#33;&#33;
