Results 1 to 7 of 7
Thread: 3 wire coolant temp sensor.
    Jan 2006
    well guys just got back from the parts store. Cant find a 3 wire temp sensor anywhere. Been asking for a 98 f-body and keep getting a 2 pin sensor. does anyone know if a 2 pin can be adapted to run a gauge? I have an extra one and thought it might work. its seems to me that you would run one lead to the guage and the other to ground and it would work.....any thoughts
    Nov 2005
    ohio
    i think i just saw one on LS1 PERFORMANCE PARTS .COM, try there, hope you find it, i think it was under ls1 to s-10 conversion parts.
    yep, just double checked, they have a ls1 3 wire temp sensor for 39.95$ it IS under s-10 ls1 v-8 swap
    San Marcos Texas
    3 wire engine coolant temperature sensor (one wire for the dash gauge, the other two for the PCM. PN 12551708).
    3-wire coolant temperature sensor connector: 12102748
    I got mine from my local dealership.
    Jan 2006
    thanks for the help guys. just so you know the part number for the pigtail has changed. it is now 88988301.
    San Marcos Texas
    <div class='quotetop'>QUOTE(vettetruck89 &#064; Feb 13 2006, 08&#58;41 PM) [snapback]44415[/snapback]</div>
    Thank you for the update&#33;
    Jan 2006
    well got the sensor and pigtail today. Coversion is nearly complete. Will be starting it up tonight for testing and then hopefully off to get exhaust tommorrow. I will soon be posting pics and info on what I used for the conversion.
