Results 1 to 8 of 8
Thread: Newbie/cam?
    Feb 2006
    Hi folks this is a great site, been watching for a wile decided to join.
    I bought comp cams (54-412-11) cam and lifters (850-16) I know I will need valve springs 918 but not sure what else i will need? ie retainers ect.. This is going in my little 4.8L and i can't wait till spring to get it out. Thanks in advance for any help.
    4.8L reg cab short box. 4:10's auburn locker, knn intake, flowmaster catback,short headers,roll pan,hypertech,160 thermostat, 8mm taylor wires,2"rear drop 20" wheels cam,lifters rods,springs and a custom tune to come. Who know after that.
    Jan 2006
    Welcome,Titanium ret. won't hurt but not totally necessary(I would), I would definitely get beefier pushrods
    What are the specs for that cam, they don't show them on comp's site?
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
    Feb 2006
    For the life of me I can't remember. I'll check tonight when I'm home. I was thinking about the rods but wasn't sure. Thanks for the answer. any suggestions or part number for the rods?
    May 2004
    Here they are:
    Part Number 54-412-11
    Engine 1997-1999 Chevrolet
    350ci,
    Generation III LS1,
    8cyl.
    Grind Number LS1 XR265HR-14
    Description
    Intake Exhaust
    Valve Adjustment 0 0
    Gross Valve Lift 0.522 0.529
    Duration At 0.006 Tappet Lift 265 271
    Valve Timing At 0.006
    Open Close
    Intake 21 64
    Exhaust 72 19
    These Specs Are For The Cam Installed At 112 Intake CL
    Intake Exhaust
    Duration At 0.05 212 218
    Lobe Lift 0.307 0.311
    Lobe Separation 114
    Recommended Valve Springs 941-16
    BTW, Welcome!
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Feb 2006
    You're Quick, I bet the ladies tell you that to LOL. Sorry couldn't resist. Are you sure about the springs? not to doubt you but I read that the 918 were the recommended spring?? Will comps high tech 5/16 7.400 rods work? part # (7955). Sorry to pick your brain but I want to get this in.
    Feb 2006
    Helooooo?
    May 2004
    Sorry for the late reply, that's what's recommended because you're running a mid lift cam but I'd install the 918's just to be safe. Yes, the 7.4 rods are correct also.
    97 GMC, 2002 LS6.
    Feb 2006
    Thank's much. Now to order and get dirty. Enjoy your weekend.
    Cheers
