Results 1 to 8 of 8
Thread: Truck A/C on 5.7
    May 2004
    Got the A/C to work on my 5.7 LS1. Here are the pics. Got the suspension back underneath it and it's ready for the motor. Here are the pics of the A/C. I need to get a little longer belt, the truck is just a little bit long but not by much. Let me know what you think.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    San Marcos Texas
    That belt might be the correct length with the other idler pulley. There should be two small pulleys.
    Apr 2005
    Hey Nitro,
    These look really, really good!! Everything is really tidy and the tensioner is in a good spot. With this kind of proximity, do you think there will be more or less stress on the tensioner? To me, it would seem that there would be less since the length of the belt is short (compared to my install). I would think this would mean there would be less slack available, so the tensioner doesn't have to work so hard....
    Did you make the mounts yourself?
    Good job!!
    93 Ext Cab w/ 99' LS1, AFR 205cc heads milled to 59cc, G5X2 cam (232/240 .595/.608@114LSA), Edel LS1 headers, 6.0L intake
    Edel IAS shocks, Hotchkis front/rear antisway bars, 3.73 Axle w/ 8.5" -10-bolt w/ Eaton Posi
    May 2004
    GMCwantsls1, This set up only comes with one pulley. I'll look again but the bracket I'm using isn't the 5.7. I'm using the truck tensioner, bracket and compressor but retained the 5.7 balancer with a little machine work. I'm sure the truck balncer is the difference in the belt length. The trucks I have at work only have one pulley on them that I can remember. The belt is around to 1/2 to 3/4" too long. The pulley is tensioned almost half way.
    93Ext5.7ltr, Yes I agree with you and I made everything myself.
    97 GMC, 2002 LS6.
    San Marcos Texas
    <div class='quotetop'>QUOTE(NITROUS &#064; Jan 29 2006, 06&#58;56 PM) [snapback]42630[/snapback]</div>
    GMCwantsls1, This set up only comes with one pulley. I&#39;ll look again but the bracket I&#39;m using isn&#39;t the 5.7. I&#39;m using the truck tensioner, bracket and compressor but retained the 5.7 balancer with a little machine work. I&#39;m sure the truck balncer is the difference in the belt length. The trucks I have at work only have one pulley on them that I can remember. The belt is around to 1/2 to 3/4" too long. The pulley is tensioned almost half way.
    Ah I understand now&#33; You used the truck compressor and bracket on a f-body crank pulley&#33;
    It&#39;s looking really positive there, Lance. I can&#39;t wait to see the finished product&#33; Keep us updated.
    May 2004
    You got it bro&#33; I wanted to try something different
    97 GMC, 2002 LS6.
    Oct 2003
    Lance...Nice A/C set-up...I think your the first one I&#39;ve heard of, using that combination on an LS1. And thanks very much for sending me the wiring schematics&#33; Gar
