Need some help fellas.
I am in the process of putting a 5.3L and T56 in a 92 SWB that had a 4.3L and a 5 speed.
The question for today is regarding fuel system.
I got the fuel pump module with the donor engine. I am wondering if the donor pump will work in the swap, and will my original fuel lines work?
I am hoping to retain the lines and add braided line to hook up to my fuel rails.
If the above is possible can I use the quick connect joints on the fuel rails or do I have to change something on the rail itself?
Hope this makes sense.
Thanks in advance
Patrick
'92 Fullsize, swb rc
5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
