Can I use a diesel 4L80E on a LS5.3
I purchased a used 4L80 with converter out of a 2003 3500 diesel and would like to know what kind of problems I will have using that diesel torque converter on my turbo LS5.3? At least until I can save the money to buy a shift kit and proper stall for my setup...
custom Holset H1 turbo
80lb injectors
comp cams turbo cam with .610 lift
3:42 rear gear on 30" tires
1957 Chevy Truck
- You may not post replies
- You may not edit your posts
