Radiator Question for a 96 Tahoe - Lq4/4l80e Swap
I am not a fan of the stock 6.0 upper radiator hose crossing over the engine bay, so I was hoping to get a radiator with both of the connections on the passenger side.
Will this radiator and fan setup work?
https://www.summitracing.com/parts/g...make/chevrolet
Brand:Griffin Thermal Products
Manufacturer's Part Number:CU-00008LS
Part Type:Radiators
Product Line:Griffin Performance Fit Radiator Combos
Summit Racing Part Number:GRI-CU-00008LS
Radiator Style: Crossflow
Inlet Location: Upper passenger side
Outlet Location: Lower passenger side
Radiator Material: Aluminum
Radiator Finish: Natural
Overall Width (in): 33.250 in.
Overall Height (in): 18.620 in.
Overall Thickness (in): 6.420 in.
Core Width (in): 28.000 in.
Core Height (in): 18.620 in.
Core Thickness (in): 2.680 in.
Row Quantity: 2
Transmission Cooler: No
Inlet Size: 1 1/4 in.
Outlet Size: 1 1/2 in.
Tube Size: 1 1/4 in.
I see no reason why it would not work, but for $600 bucks I think I could handle the radiator hose running across the engine bay... PM me your email and I will send you a pic of my setup on my 98 tahoe... I kept the hose, used my stock radiator and used some ebay dual fans... I had a local fab shop make a simple cover for the top
- You may not post replies
- You may not edit your posts
