Results 1 to 2 of 2
Thread: 2013 ZL1 LSA Swap-What Parts Are Needed?
    Sep 2012
    I recently acquired a totaled 2013 ZL1 automatic from a friend(LSA engine/6l90 trans). What parts should I keep off of the car besides the engine/trans? I am not very familiar with the gen4 electronics. I know I need the engine/trans, pcm, fusebox, pedal assy, and harness. I don't have a particular vehicle that it is going in yet, I just want to cover my bases. Thanks Fellas!
    San Antonio, TX
    Maybe some of the charger cooling system if you're into making it fit.
    The slip yoke from the trans for your new driveshaft.
    Trans cooler line fittings and lines.
    Fuel pump if you wanna make it fit in the conversion vehicle.
