Results 1 to 2 of 2
Thread: 5.3 Junkyard Build. Need inputs before proceeding.
    Apr 2016
    Like it says im brand new to this.
    Ive got an 02 5.3 from some guy off craigslist for $200. Block/Heads/Crank/Rods/Oilpan/NoSensors. I want to put it in my 92 Ext cab Silvy to take place of the 350. As of now my 350 isn't blowing up soon so I want to put the 5.3 on an engine stand and build it throughout the time. Ive done tons of research for the past 6 months before buying the engine. And I want opinions if the parts list I have will work as a DAILY and a weekend warrior.
    (500-600)HP Goal
    Intake: Truck intake
    Throttle Body: Aftermarket 80mm TB
    Injectors: 60lb siemens
    Fuel Pump: Walbro 400
    Heads: 706 heads
    Valvesprings: LS6
    Pistons: OEM cup dome pistons
    Rods: OEM 143 connecting rods
    Crank: OEM 5.3 crank
    Harness/Comp/Etc: NOCLUENEEDHELP
    Turbo/Bov/WG: On3 76mm, 50mmBOV, 44mmBOV
    ARP main stud Kit/ ARP head bolt kit
    LS9 Head Gaskets
    Pushrods: 7.425 pushrods
    Camshaft: LS6 camshaft
    Lifters: OEM Lifters
    Rockers: OEM 1.7 ratio Rockers
    Get yourself some ARP connecting rod bolts as well. As far as the PCM I'd recommend Nelson Performance. They know what they're doing and most importantly have good customer service.
    2000 RCSB
    LQ9
    Torquer V2
    T56 Magnum
    305 drag radials
    3/4 lowering kit
