Results 1 to 1 of 1
Thread: 95 GMC 5.3 turbo build
    Jan 2016
    hello all, im new to the site (have been a reader for years) and have finally started 95gmc turbo build. I wanted to run a few things buy you guys to see if im on the right track or if i should make a few changes. Here is my current list of items i have for the build
    5.3 motor (out of a 2004 Tahoe with 41k miles on it)
    Factor harness, tack pedal and module, ecu and fuse box
    Dirty Dingo mounts
    LS1 heads (were given to me as i'd like to drop the compression some for more top end boost and pump gas drive ability
    LS9 7 layer head gasket
    ARP stud kit
    LS6 cam and springs
    Deka 80lb injectors
    Things i haven't purchased but not 100% which route i should go
    GT45 Turbo? (im sure i have tons of options here
    not sure on the best fuel line system yet (open to thoughts here guys)
    The 95gmc is a 5 speed manual with 3.73 rear end. i know 100% of you guys will say throw the manual away but i plan on putting different gears in and running the tranny until its blown. The truck currently has a walbro pump in the tank.
    Thanks for any info or changes you guys might come up with.
