Need help!!!!
Ok guys I'm putting a 2002 LS1 out of a Trans Am in my 91 Sport truck. I using a Dirty dingo A/C bracket to keep my factory air. I am also using a power steering bracket out of a 5.3 but when installed the power steering pulley sets to far forward and the belts do not line up. Any suggestions !!!
You need to either run truck brackets, water pump balancer and accessories or car brackets, water pump, balancer and accessories. You can't mix. The LS1 intake won't fit with the truck accessories. The dirty dingo bracket is for the truck brackets.
- You may not post replies
- You may not edit your posts
