Results 1 to 3 of 3
Thread: LS1 fuel rail
    Wichita Falls, TX
    LS1 fuel rail
    I put a '97/'98 LS1 into my 85 C10. I plan on running a 91 suburban tank under the bed or a cell, but I'm not sure how to plumb the fuel lines in. I believe I have returnless style fuel rails, and I'm not sure what to do with the return line off of the sending unit.
    San Antonio, TX
    The return line needs to come off the rail back to the tank.
    You can use the return line on top of the fuel bucket if that's what you're asking.
    Jun 2015
    Quote Originally Posted by PunishedC10 View Post
    Hey mate just do a google search it will show you how. But there is a fuel filter with built in reg from I think the corvette. Mount it up near the tank then 1 line from tank to filter reg. Then one line filter reg to tank and one line to the fuel rail. Failing that, like if you wanted to run boost you could run an external reg but you would have to run 2 lines the lenght of the vehicle. I've never done it but that's my understanding.
    clay
