Results 1 to 6 of 6
Thread: Gasket kit
    Gasket kit
    Hey guys, I did a quick search but couldn't find what I need. I'm looking to redo all the gaskets on my LQ9(out of 05 escalade)while its out....oil pan gasket, rear main seal, etc. is there a kit that has all of them or do I have to purchase individually? What gaskets would you guys replace? Just want to make sure I have all of them on my list. Felpro the way to go? Thanks for the help!
    Ethan
    First & only 4th gen Ram 4x4 in the 12's NA 12.747 @ 104.07 (1.663 60')
    2012 Black SC 4x4 1500 Hemi ARH longtubes, Vararam intake, Circle-D 3000, Meziere E-water pump
    Moe's 87mm throttle body, efan, 2010 frontend swap/4.56 gears, Greene Racing tune, E-power steering pump
    Anyone?
    Ethan
    Sep 2012
    Quakertown, Pa.
    You can always check Flea-Bay. Sometimes deals can be had there. Good luck!!!!!
    John
    Jan 2014
    Las Cruces NM
    I just use felpro from autozone and buy them individually. Pan, front and rear cover, And valve covers. If you pull the heads get gm gaskets and bolts and don't forget a new crank bolt.
    Quote Originally Posted by Chevydillan View Post
    Thanks man, that's exactly what I did....looked up the part numbers on felpro website and then bought them at o'Reillys. felpro was about $60 cheaper than oem off the cheapest chevy wholesale parts website I could find. I bought the intake gasket as well. Think that was the most expensive one. O Reilly's even had the crank bolt.
    Ethan
    Nov 2013
    Fort Hood, TX (for now)
    For my '05 lq9 I bought the complete gasket/seal set from rock auto. It was extremely expensive though!
