If I was to run a 200 wet shot on a 5.3, what stand alone fuel system for the nitrous would be good? High pressure? Low pressure? Just need to know the in an outs of it cause I'm new to this. Would be running 91 in my main tank.
I'm just running a cheap jegs 1 gallon fuel cell and holley blue fuel pump and regulator. I run 5-6lbs flowing fuel pressure.
Never finished it, but i was planning on the same setup as DTR81.
A low pressure dedicated setup would be the best to go with. For the fuel I'd suggest going with C16. Even though it's a leaded based fuel the amount your using won't hurt the motor at all. We offer a low pressure setup and an adjustable setup. Both can be seen here ---> http://www.nitrousexpress.com/safe-systems.html
-Chris
nitrousexpress.com
facebook page
youtube channel
join newsletter
Pm, Call (888)463-2781, or email Trey@nitrousexpress.com for Tech or sales
MADE Proudly IN THE USA
What kit and what type of design did you have in mind?
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
done one with low pressure setup, going from 6psi to 5psi changed the fueling a good bit and also netted more power by leaning the jetting out
used a complete kit from NX
we used c16 in the tank for the nitrous fueling
2014 Xsport- 3.5 Eco boost
412 Motorsports
