Results 1 to 3 of 3
Thread: 4L80 conversion
    The Garage
    4L80 conversion
    So I read this article:
    http://www.ls1truck.com/forums/front...rans-swap.html
    and I am unclear on 2 things.
    1-I have an '06 Silverado (not an Avalanche), what do I do about the driveshaft? Do I take it to a local shop, have it shortened and a yoke for an 80 installed? What about the larger output shaft on the 80? Can I buy a driveshaft for an HD with yokes that will plug right in?
    2-How exactly do I plug the 80 into the harness, being that my truck came with a 60?
    I do have the tubular crossmembers.
    San Antonio, TX
    The best solution regarding the driveshaft is to get the correct one made after all the measurements have been made. Now, many ppl remove the 60e slip yoke and install the 80e slip yoke.
    This works sometimes, however, be sure the yoke slips into the tailshaft far enough. I like to see about 1/2" of slip yoke sticking out; just enough for movement. If there isn't any travel for the yoke, you'll beat up the trans.
    The yoke is about $80, get yourself a good spicer ujoint as well.
    As for the electrical side.
    We offer a PnP harness. Simply plug this harness into the trans, and the other side of our harness into the original trans harness.
    We supply an ISS harness as well, plug that in and run the two wires to the pcm.
    Using all new OEM connectors and terminals.
    Flash a pcm using an HD vin or use hptuners beta version Segment Swap utility.
