Results 1 to 8 of 8
Thread: Will it fit? 5.3 Swap.
    Jan 2015
    The title might be a little bit off for this post, because I know it will fit. But a better question would have been will this engine swap without any major modifications? I want to swap a crate engine in a tired 2002 Silverado that currently has a 5.3. This engine is a 5.3, but I believe it's listed as an engine for the 1999. Reason I ask, the engine according to my VIN number, they want around 4k with a $2,000.00+ core, not to mention I was wanting to keep my current engine. Anyone know what differs from the 2002's to the 1999's and if this would be possible or a hard swap? Here's the engine I'm looking at.
    http://www.citycratemotors.com/parts...M-Engine/2282/
    Mar 2013
    Long Beach California
    ha. still dont understand what your question is.... your replacing your motor with... the same motor.... why would there be an issue? unless your going from a regular to flex fuel(2006+ i think), it will be the same... a 5.3 is.. well.. a 5.3 so whats the question??
    CALI LEGAL ENGINE SWAP!
    Dec 2008
    South Carolina
    it will work just fine. Direct swap
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
    Jan 2015
    That's good to know. Kewljay, I was just wanting to confirm because my truck is an 02. There are about 8 different engine assemblies for the 5.3 when you get ready to buy a crate, all with different numbers. This one is for a 1999 and for some odd reason this one is a bit cheaper then the one listed for 2002, and the core on this one is only $300.00 as oppose to the $2,000.00+ core for the engine 5.3 they call for an 02. Makes no sense to me, but that's how it is. It's good to know this one will fit. I've been throwing around the idea of getting an LKQ engine between 100-125k miles and putting a new water pump, timing set, and gaskets on it to replace my tired 300,000 mile engine. It would run me about $1,500.00 for the entire thing including the used engine, all new gaskets, new timing gears / chain, spark plugs / wires etc. Or I can go ahead and get this engine for an extra $1,300.00 shipped to my door. So it seems like this would be the best route for long term use.
    Jan 2015
    Better yet, one more quick question. Will a 350 replace a 5.3 engine in these trucks and bolt up to a 4l60E? I know it might sound like a silly idea or a step backwards. But the reason I ask, I don't use the engine for any time of racing nor do I need top-end power. I actually pull a trailer all day with light - medium duty weight and the low end of the 350 would suit me. The 350's are about half the price of 5.3's for replacement also when need be. I've had plenty of 350's with several hundred thousand miles and zero issues. These 5.3's seem like stout engines until you run into the Casteck head issues, then that's enough to scare me away. We're the 6.0's effected with these heads also?
    Dec 2008
    South Carolina
    Quote Originally Posted by 02z71 View Post
    please tell me your joking....
    Mar 2013
    Quote Originally Posted by chvy=power View Post
    Lol. That's not a step backwards. That's a MAJOR LEAP... If you want torque, then get a 6.0. The swap Will be just as easy as a 5.3
    Plus idk how smog works where your at but usually you can't go with an older motor. And on top of that, that would require so much work to put that thing in there. You need to get that idea out of your head asap....
    Dec 2008
    South Carolina
    yea the only thing a good that 350 is good for is a boat anchor. and the castech head rumor is bull. Iv never seen a 5.3 head leak becuase of a casting defect
