Results 1 to 6 of 6
Thread: 1201MAX Randy
    Dec 2014
    Central ,Minnesota
    1201MAX Randy
    I have a few questions. First off I bought a 5.3 LS motor to stick in my 52 Chevy RatRod. I am going to carburate it and put a MSD box to control the coils, I have shorty headers on the way and am looking at my next move. What I want to do is put in 1.8 rockers cause at this point I will not be porting the heads or doing a cam. My 52 Rat Rod is very light as it has a tube racing frame so a bunch of HP wont be needed. When I got the truck it had a 1973 350 with a 4barrel that put out 155hp from looking up the Block and Heads on it, the LS I have is out of a 1999 gmc sierra and from what I looked up should put out 270HP and 330Torque.Any help with what I need to install the 1.8 rockers would be appreciated.
    Thanks, Randy
    Nov 2009
    SAN ANTONE
    if you install 1.8 rockers you may also need to upgrade your stock valve covers for clearence.
    Dec 2014
    Central ,Minnesota
    I have been doing some research and from what I seen you can get by with stock valve covers. I question the springs and push rods though.
    52 Chevy Truck? Post some pictures. What frame are you running to mount that 5.3 to? Trans?
    Dec 2014
    Central ,Minnesota
    The frame has a camaro/nova subframe and tube frame the rest of the way back,stock car racing frame. It has a Turbo350 trans and Ford nine inch diff (open carrier). I have to modify where the motor will mount as it will sit back quite a bit in the subframe, there was a sbc 350 in it originally. I put a couple pictures in an album on my profile, cant figure out how to put it in the thread yet.
    Nov 2011
    New Brunswick, Canada
    Cool, Ive had a 52 for years. Maybe ill start working on it again in a couple years, its got a 79 nova front subframe and a 2x4 tubing frame. Keep us posted with ur build.
