Limited Slip POSI for 8.5" GU4 read end 2WD S10. Any salvage yard direct swap ?
I have a GU4 8.5" rear end which came out of a 1998 S10 2WD.
My local yard has tons for GM stuff.
Is there any direct swap limited slip that will this rear end ?
Can someone please confirm that the pics below is the S10 with 8.5" rear end?
Thanks
Waid
- You may not post replies
- You may not edit your posts
