Results 1 to 10 of 29
Thread: going for it lq9 /1995 silverado
    Oct 2014
    i have read until my eyes hurt and taken notes on it all this winter my 95 silverado is getting a lq9 . my 4l60e has been heavily modified to handle extra power as has most of the drivetrain gears axles locker ... i am going with nelson performance to handle the wiring and dirty dingo for the mounts stock radiator should handle cooling.. all the threads have been very helpful but some info conflicts other info who can help me the most? i have questions whats needed to run current 4l60e? stock exhaust manifolds off ??? or buy custom headers? smog is not an issue where i live so i can delete egr and have custom tune to best use what i have,,, where should i go for that? i want to leave engine internally stock but externally is open game.. a complete list of needed mods would be a dream cuz looking at so much info and trying to pick and choose whats best for my application gets to be a little stressful thanks in advance for helping the new guy to your page..
    Oct 2014
    also is there a fuelpump capable of feeding my motor that will fit in my stock fueltank ? or do i need one of those also
    Sep 2010
    not sure how the stock fuel pump is setup on the TBI trucks so I cant tell you what fits the stock sending unit but if there isnt anything out there then you may have to swap the sending unit and possibly the tank for a Vortec style one. An OEM Vortec fuel pump will run the 5.3 with no issue.
    Sep 2009
    NE Ohio
    The fuel pump should be fine. Unless its old then swap it out for a new one. I am running my stock pump on my LQ4 and it is plenty. All stock except for CAI and headers. The new ECU should be able to control it. Its all controllable with a tune. Headers are your choice. Depends on your location. Salt in the winter will eat them alive unless you dont plan on driving it in the winter.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
    Aug 2012
    Portland, OR
    I am almost done with a 5.3/t56/14bolt swap into my 95 ecsb. 95 is still TBI so your fuel system operates at about 10-12 PSI IIRC. So you will need a stock vortec 96-98 fuel pump because the ls engines need 58 PSI. It is AcDelco Ep-381. Or you could go for something like a walbro 255 if you plan on more power in the future. Here is a link to my build thread, I haven't gotten around to starting one here yet. I also stopped posting as much in it. I can try to answer whatever questions I can, but remember I did a t56 and was 5 speed to begin with so I can't help with that.
    http://www.gmfullsize.com/forum/showthread.php?t=259002
    Oct 2014
    Going 6.0 locating fuel pump isn't an issue. Even swapping the tanks isn't an issue if need be. What about tranny issue ? No salt here. So no worries.
    Oct 2014
    6.0 4l60e specifics.
    Few more specific questions for you who have done it. What fuel pump will run my 6.0 but will fit in the tank of a 1995 silverado ?? And. What's required to bolt my built 95 4l60e up to my 6.0? Spacers? Parts from the 4l80e that came behind the 6.0 ?
    Aug 2012
    Portland, OR
    Quote Originally Posted by Jeebalow View Post
    Did you miss this?
    Oct 2014
    Did you miss this?
    I did miss that. Thanks for the info. Narrowing it down one step at a time
    Aug 2012
    Portland, OR
    Have you read this?
    http://www.ls1truck.com/forums/lsx-t...onversion.html
    If not read it at least 5 times. You'll get more from it each time. That should answer some of the questions you have.
