Bolting an ls1 flywheel into an 06 lq9 but there seems to be a lot of slack on the flywheel, is there an aftermarket flywheel bolt for this set up? I used the stock ls1 flywheel bolts. any help would be greatly appreciated.
flywheel or flexplate?
2014 Xsport- 3.5 Eco boost
412 Motorsports
flywheel
So the bolts are bottoming out?
If it's the factory 6.0 bolts, and was in front of an auto, it most likely had a flex plate spacer that's .4 thick
I had a nv3500 5 speed behind a 4.8 and used the factory bolts. Also used the same bolts for ls1 style flex plate and 4l80e behind the 4.8, and now the same flex plate and bolts behind a ls1.
I'm guessing you have the long bolts for a 6.0 with automatic.
Lq9 never had a spacer
412 Motorsports
Ahh, didn't know that. Sorry
