Results 1 to 4 of 4
Thread: Tcc wire please help last wire
    Aug 2013
    Clarksville, tn
    Ive got one wire left to hook up and its the tcc wire i know what it is and what it does i just need to know where the wire is located on my 94 c1500, is it under dash or behind glove box and what color?
    Sep 2012
    Quakertown, Pa.
    If it's anything like my '93, the color is tan/black. It's located on connector C216, position A-4. This connector should be the right hand connector on the old PCM when viewed through the removed glove box
    That is what my GM service manual shows.
    Now here's some info that says it may be in a different slot on the same C-216 connector:
    http://67-72chevytrucks.com/vboard/s...d.php?t=465888
    Read the first post and select your engine/trans combo. Click on the PDF file for the wiring diagram.
    John
    Aug 2013
    Clarksville, tn
    It was the purple wire, it was in the black and blue connector.
    Aug 2011
    Ellsworth Air Force Base, SD
    Did you get it to work? You never sent me back a text to let me know. If so, how's it running?
    1994 Chevy C1500 RCSB 05' DBW 5.3 Conversion Complete
    My build
    Coming soon ....... Full Repaint, 214/220 Cam, Yukon Posi with 3.73's, remove body lift
