I have the factory 05' Silverado dual fans installed on my truck, are these fans single or dual speed fans? I am not sure whether I need to wire them with a 2 or 3 relay setup.
1994 Chevy C1500 RCSB 05' DBW 5.3 Conversion CompleteMy build
Coming soon ....... Full Repaint, 214/220 Cam, Yukon Posi with 3.73's, remove body lift
how many wires coming out of each? if 2, then they are single speed and need 3 relay setup. if 3 wires, then they are dual and only need 2 relays.
CALI LEGAL ENGINE SWAP!
Those fans have a one speed motor.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
So this is how Brendan from Lt1swap.com told me to wire the fans.
Is this the proper way to wire these fans because that's how I wired them?
yep. thats the same guide i used. works great. assuming your pcm is programmed to turn them on....
That's what I asked for, the donor vehicle for the engine and PCM had dual fans on it. I will have to wait till Monday to test it, my tracking number shows my computer gets delivered back to me then.
Ya, that's an oem wiring schematic, works great.
regardless of pcm, you'll be able to use both fans and have them function correctly. programming takes care of that.
Nelson Performance
NP on Facebook
Youtube Channel
^^^ MAKES A DAMN GOOD HARNESS TO SOLVE ANY ISSUES ALSO ^^^
still running one of the first ones ever made
Simple: 408 on steroids!
single digits coming soon!
Have to wait till tomorrow to test it, my computer did not show up in the mail even though the tracking number said today. My original plan was to buy one from Nelson, but my wife dug into my budget a little. I am putting the Nelson's fan harness on my summer upgrades list with a cam, stall, Nelson tune, and full repaint.
Can someone repost that wiring diagram. Or link it the one posted said it's been deleted
