Results 1 to 4 of 4
Thread: Park neutral switch question
    Jan 2014
    Las Cruces NM
    Just started my swap today. Pulled both engines and trannies.
    So here is the first of I'm sure about 1 million questions to come.
    My donor tahoe is an 2004 2wd automatic 5.3
    The truck it's going in is an 97 rcsb 2wd.
    The donor trans has only 1 plug for the park neutral switch and the 97 had 2. Do I just need to swap over the original 2 plug switch or will the 1 plug switch work?
    Apr 2013
    Houston
    Quote Originally Posted by Chevydillan View Post
    I believe you can just put the switch with 2 plugs on the trans and plug it in
    Jan 2011
    Mcalester,okla.
    Quote Originally Posted by Slow04xcab View Post
    Yes just put the 2 plug switch on it
    Jan 2014
    Las Cruces NM
    Thanks guys
