Results 1 to 10 of 19
Thread: What do I do with this wiring?
    Aug 2011
    Ellsworth Air Force Base, SD
    I need help with some wires. I found two connectors that had no home hanging on the back of my harness near the passenger O2 sensor. I started pulling wires out of the harness and traced them to the C100 connector.
    What are these and do I need them? Do I need anything for that matter that is on the C100. Here is the wires on the C100
    Thanks for your help
    1994 Chevy C1500 RCSB 05' DBW 5.3 Conversion Complete
    My build
    Coming soon ....... Full Repaint, 214/220 Cam, Yukon Posi with 3.73's, remove body lift
    not sure what wires are what on the 94, i have a 96 & they're different, but your speedo, tach, oil pressure, temp, check engine & a few others are in that plug & you will need to tie into them.
    Aug 2011
    Thanks for the reply. Ok I figured it out after some reading and got the wires pulled and labeled. I still have a few questions now about left over wires. First 3 wires that go the connector that plugs into my tac module for drive by wire. What are these, and do I need these 3 wires?
    Second, I have 2 wires that go some weird connector on my negative battery cable. What's the fix for this one?
    Thanks for your help.
    My build
    Mar 2013
    Long Beach California
    CALI LEGAL ENGINE SWAP!
    Aug 2011
    Ok that link really helped out, thanks kewljay. I discovered that those wires go to my cruise control switch.
    Now, if anyone has information on the other 2 wires on that battery generator thingy, I would greatly appreciate it.
    My build
    Sep 2009
    NE Ohio
    I can look up some info on alldata for you.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
    Sep 2009
    NE Ohio
    What model did this motor come from? What is the 8th vin number from donor vehicle?
    Sep 2009
    NE Ohio
    Generator battery control module. That is what is around the negative battery cable.
    Aug 2011
    Thanks brother, I appreciate your help. Here is the printout from the donor.
    My build
    Aug 2011
    It's a module of some sort with a 10 pin connector
    The numbers on the top of the module read 15137027
    The bottom reads RVGB 621375
    My build
