Results 1 to 7 of 7
Thread: Dirty Dingo brackets?
    Dec 2013
    Ok I thought I found the right motor mounts/brackets for my LS swap and I talked to dirty dingo and they are saying I need part # DD-2550CC. I have a 1990 silverado with a 350/700r4. Are these they right ones I need please. Thank you
    [/B]90' silvy 4.8 swap in the works.[/B]
    Sep 2009
    NE Ohio
    if your truck is a 2wd then yes those are the correct ones.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
    That's the brackets I used they are jam up easy to install I would buy them again if I do another swap
    I used similar mounts in my C10 swap and they made the install that much easier.
    Mine seem to off by about 1/2 in. It seems like they are wider then the mounts?? In a 94 sbrc
    Sep 2011
    I have used their mounts on 2 swaps,, I highly recommend them
    I used the dirty dingo r4 ac bracket with truck accessories. Ly6 water pump to clear ls1 intake and 5.3 alternator/ powersteering bracket with dirty dingos idler relocation pulley with my trucks stock powersteering pulley and a 6.0 harmonic balancer.
