42lb 8.1 Marine Injectors
Used 42lb marine fuel injectors
Part # 17113739
Simple plug and play for GM trucks from 99-05
Interchange Part Number: 17113739, 25348180, 25176061
Electrical connector type: Multec II, Delphi (stock fit for GM trucks).
Fuel delivery type: Delphi 3-hole disc, excellent fuel atomization
Overall Length: 2-5/16 inches, 58 mm
Oring to Oring: 1-7/8 inches, 48 mm
Diameter: 17 mm
Orings: Top and bottom, 14.5 mm
Resistance: 12.5 Ohms (high resistance)
GMC trucks and 496 Marine engines
2001 ECSB 5.3, Comp cam, Crane rockers, LS6 springs, Mac CAI, P&P throttlebody, OBX lt's and ory, Hooker Maximum Flow, LS1 fans, 160 tStat, Transgo shiftkit, WHEATLEY Tuned, 4.10 gears and Truetrac by axisT6
