Results 1 to 10 of 35
Thread: Nelson engine harness
    Oct 2013
    San Antonio, TX
    incorporated
    We offer an LSx, non-emissions, show quality engine harness that can be custom designed to your exact needs. Extra effort is made to ensure the harness layout comfortably fits the engine while maintaining an exact fit.
    All harnesses are built with new, OEM connectors, terminals and seals. Every crimp is performed with approved tooling.
    This ensures 100% continuity throughout the entire engine harness.
    Every harness has a fuse block incorporated, ignition relay, fuel pump relay, data link connector with an LED SES light and our easy 4-wire hookup.
    All wiring is TXL heat rated (250°F) which has a thin coating to reduce the size of the harness thickness.
    This allows for easier bending and routing, which gives a clean look.
    The harness is then covered with a black nylon mesh that protects the wires from abrasion and gives the harness a professional look.
    Before the engine harness is shipped to the customer, it is thoroughly tested by verifying each pin and terminal pinout. The harness is installed on our engine test stand to verify functionality and operation.
    We go a step further to ensure our customer is never faced with a harness issue by verifying every component is functioning while the engine is running with our diagnostic tool.
    A multi-point check list ensures each sensor is verified.
    When the customer receives the harness and installs it, they can rest assure that their conversion will start up the first time!
    In addition to engine harnesses, we also offer PCM/ECM programming, fan control harnesses and misc wiring solutions.
    Oct 2013
    San Antonio, TX
    For more information or to place an order feel free to contact myself via email at roy@nelsonperformance.com or give us a call at (210)626-0278
    Oct 2013
    San Antonio, TX
    back to top
    Sep 2011
    Top notch quality guys......... I have one on my truck, can't go wrong with Nelson
    ive got a special order being done
    Simple: 408 on steroids!
    single digits coming soon!
    Oct 2013
    San Antonio, TX
    Quote Originally Posted by skeet View Post
    Just finished up your harness, tested it and works great and looks even better. Enjoy!
    thanks Roy!!
    Oct 2013
    San Antonio, TX
    Back To Top
    May 2014
    What do they run for price wise?
    Nov 2009
    SAN ANTONE
    $500 DBC bare harness, harness is uncovered, no o2 sensors, no maf
    $750 99-02 DBC harness with all necessary connectors
    $850 2003-2006 DBW harness with all necessary connectors
