Results 1 to 10 of 12
Thread: i need help (timing increased by itself )
    hi guys
    i have a sierra 2001 1500 , 5.3 bolt ones + milling oil pump + thermostat + PRC dual spring titanium , NGK TR5IX spark plug + MSD plug wires
    when my tuner tune my car we faced detention on gear 2 at wot with a full tank it became a less than before , after 3 days i took my car to a dyno to see my numbers here :
    they used wideband at rear exhuast my A\F was 13.37
    i took it back to my tuner to see what's wrong with it , now my tuner no matter what he does it keep boosting timing it's around 35-36 at wot
    the truck was v6 then i swaped it with a 2004 5.3 i send the PCM to near by workshop which we figured out out they put Suburban stock file from 2001 !! could it be related to this ?
    thanks in advance guys
    timing isnt going to increase on its own it will pull timing if needed, suburban stock does not pull anywhere near 35-36* of timing in stock form. the timing you see at WOT is the timing the tuner set it at.
    side note if youre running 35-36* of timing on pump gas some serious is going to happen to your motor i've ran as much as 38* and that was on race fuel
    how do you know its 35-36 at WOT? something just isnt adding up
    Simple: 408 on steroids!
    single digits coming soon!
    HPtuner
    yup i know something will happen soon if i don't fix this last night tuner set it at 25 to see if it will stay on it , it just keep increasing on it's own
    could it be bad sensor ? or wire
    The pcm cannot add timing on its own. Period. Find a new tuner.
    he set it 25 at wot it reach 35 ?
    i will talk to him to see whats up
    Arizona/Utah
    Can you post a log and the wot timing tables.
    i will get it tonight kerrige
    If only i could find one to pull timing on its own lol
    buy mine lol
    we changed the file for new one , the old one is for a flix fuel engine !!
    i will dyno it next weekend thanks a lot guys timing now set at 28
